Server Configurator (Utility)
Last Updated: 3 minute read
Version2026 R2
LanguageEnglish
Encryption tab properties
This tab allows you to specify the following properties:
Note
In a cluster environment, you must set up your cluster and ensure that it is running before you create certificates for all the computers in the cluster environment. After that you can install the certificates and do the registration using the Server Configurator for all the nodes in the cluster. For more information, see the Certificates guide for Milestone XProtect products.Certificates guide for Milestone XProtect products
Name
Description
Task
Server certificate
Select the certificate to be used to encrypt the two-way connection between the management server, data collectors, log server, and recording servers.
Enable encryption to and from the management server
Enable server encryption for recording servers or remote servers
Event server and extensions
Select the certificate to be used to encrypt the two-way connection between the event server and the components that communicate with the event server, including the LPR server.
Enable event server encryption
Streaming media certificate
Select the certificate to be used to encrypt communication between the recording servers and all clients, servers, and integrations that retrieve data streams from the recording servers.
Enable encryption to clients and servers
Mobile streaming media certificate
Select the certificate to be used to encrypt communication between the mobile server and the mobile and web clients that retrieve data streams from the mobile server.
Enable encryption on the mobile server
Registering servers
Name
Description
Task
Management server address
The address of the management server typically includes the hostname or the fully qualified domain name (FQDN) of the computer.
By default, this address is only active from a computer in the XProtect VMS where the management server is not installed.
As a rule of thumb, the management server address should not be changed from a computer that has the management server installed.
However, if, for example, you use the Server Configurator in a failover setup, you might have to change the address from the management server computer. This could be within a cluster failover environment or in another failover setup scenario.
  • To activate the Management server address field from a computer with the management server installed, click the pen (pencil_edit.png) symbol.
Important
If you update the management server address, you need to access each of the computers that have components installed and update the management server address with the new address information.
Click for more information about the implications of changing the management server address from a computer that has the management server installed:
Changing the host name of the management server computer
Register
Register the servers that are running on the computer with the designated management server.
Register a recording server
Language selection
Use this tab to select the language for the Server Configurator. The set of languages for the Server Configurator corresponds to the set of languages for the Management Client.
Name
Description
Choose language
Choose the language of the user interface.
Note
To avoid conflicts between the failover cluster and VMS Server Configurator, pause the cluster before you start tasks in the Server Configurator. The Server Configurator may need to stop services while applying changes, and the failover cluster environment may interfere with this operation.
