Refresh site hierarchy
Version2026 R2
LanguageEnglish
Regularly the system automatically synchronizes the hierarchy through all levels of your parent/child setup. You can refresh it manually, if you want to see changes reflected instantly in the hierarchy, and do not want to wait for the next automatic synchronization.
You need to be logged into a site to perform a manual refresh. Only changes saved by this site since the last synchronization are reflected by a refresh. This means that changes made further down in the hierarchy might not be reflected by the manual update, if the changes have not reached the site yet.
  1. Log into the relevant site.
  2. Right-click the top site in the Federated Site Hierarchy pane and click Refresh Site Hierarchy.
    This will take a few seconds.
