Move non-archived recordings from one storage to another
Version2026 R2
LanguageEnglish
You move recordings from one live recording database to another from the Record tab of the device.
  1. Select the device type. In the Overview pane, select the device.
  2. Click the Record tab. In the upper part of the Storage area, click Select.
  3. In the Select Storage dialog box, select the database.
  4. Click OK.
  5. In the Recordings Action dialog box, select if you want to remove already existing - but non-archived - recordings to the new storage or if you want to delete them.
  6. Click OK.
