Mail Server tab (options)
Version2026 R2
LanguageEnglish
On the Mail Server tab, you can specify the settings for your system's mail server.
For more information, see Notification profiles.
Name
Description
Sender e-mail address
Enter the e-mail address that you want to appear as the sender of e-mail notifications for all notification profiles. Example: sender@organization.org.
Mail server address
Enter the address of the SMTP mail server used to send e-mail notifications. Example: mailserver.organization.org.
Mail server port
Enter the TCP port used to connect to the mail server. The default port for unencrypted connections is 25. Encrypted connections typically use ports 465 or 587.
Encrypt the connection to the server
Encrypts communication between the management server and the SMTP mail server using STARTTLS. STARTTLS upgrades an existing unencrypted connection to an encrypted connection using SSL/TLS.
Server authentication
Select the authentication method required by your e-mail service provider.
None: Connect without authentication.
Basic: Authenticate using a user name and password.
Client credentials flow: Authenticate using OAuth 2.0 client credentials flow.
Authorization code flow: Authenticate using OAuth 2.0 authorization code flow.
Some providers are moving away from password-based authentication and may require an OAuth 2.0 authentication method instead. Refer to your e-mail provider's documentation for the recommended authentication method.
Client ID
Enter the client ID from your e-mail provider's OAuth 2.0 configuration. The client ID identifies the application when requesting access to send e-mail.
Client secret
Enter the client secret from your e-mail provider's OAuth 2.0 configuration. The client secret is used together with the client ID to authenticate the application.
Token endpoint
Enter the token endpoint URL from your e-mail provider's OAuth 2.0 configuration. The management server uses this URL to obtain access tokens for authentication.
Scope
Enter the scope value from your e-mail provider's OAuth 2.0 configuration. The scope defines the permissions requested when obtaining an access token.
Refresh token
Enter the refresh token from your e-mail provider's OAuth 2.0 configuration, if required. The management server uses the refresh token to obtain new access tokens when existing tokens expire.
