Issue: Change of SQL Server and database location prevents database access
Version2026 R2
LanguageEnglish
If the location of SQL Server and the VMS databases has changed, for example by changing the host name of the computer running SQL Server, the recording server's access to the database is lost.
Solution: Change the connection strings to reflect the change of SQL Server and database. See Change the location and name of a SQL Server database.
