Install XProtect Management Client through Download Manager
Version2026 R2
LanguageEnglish
If there are several administrators of the XProtect system or you simply want to manage the XProtect system from multiple computers, you can install the Management Client by following the instructions below.
Note
XProtect Management Client is always installed on the management server.
You can download the component from Download Manager, see Install XProtect components through Download Manager.
To install XProtect Management Client:
