Give users permission to lift privacy masks
Version2026 R2
LanguageEnglish
By default, no users have permissions to lift privacy masks in XProtect Smart Client.
To enable/disable the permission:
  1. In the Site Navigation pane, select Security and then select Roles.
  2. Select the role that you want to give permission to lift privacy masks.
  3. On the Overall Security tab, select Cameras.
  4. Select the Allow check box for the Lift privacy masks permission.
Users that you assign to this role, can lift privacy masks configured as liftable masks for himself/herself as well as authorize the lift for other XProtect Smart Client users.
