Enable server encryption for recording servers or remote servers
Version2026 R2
LanguageEnglish
You can encrypt the two-way connection between the management server and the recording server or other remote servers that use the data collector.
If your system contains multiple recording servers or remote servers, you must enable encryption on all of them.
For more information, see the Certificates guide for Milestone XProtect productsCertificates guide for Milestone XProtect products
Note
When you configure encryption for a server group, it must either be enabled with a certificate belonging to the same CA certificate or, if the encryption is disabled, then it must be disabled on all computers in the server group.
