Enable Bing Maps or Google Maps in XProtect Smart Client
Version2026 R2
LanguageEnglish
To allow XProtect Smart Client operators to use a different key than the key from the Smart Client profile, you must enter the key in the settings in XProtect Smart Client.
Steps:
  1. In XProtect Smart Client, open the Settings window.
    Open the Settings window in XProtect Smart Client.
  2. Click Smart map.
  3. Depending on the map service you want to use, do one of the following:
