Enable and disable fisheye lens support
Version2026 R2
LanguageEnglish
The fisheye lens support is disabled by default.
  1. In the Site Navigation pane, select Devices and then select Cameras.
  2. Select the relevant PTZ camera in the Overview pane.
  3. On the Fisheye Lens tab, select or clear the Enable fisheye lens support check box.
Specify fisheye lens settings
  1. On the Fisheye Lens tab, select the lens type.
  2. Specify the physical position/orientation of the camera from the Camera position/orientation list.
  3. Select a Registered Panomorph Lens (RPL) number from the ImmerVision Enables® panomorph RPL number list.
    This ensures the identification and correct configuration of the lens used with the camera. You usually find the RPL number on the lens itself or on the box it came in. For details of ImmerVision, panomorph lenses, and RPLs, see the Immervision website (https://www.immervisionenables.com/).
    If you select the Generic dewarping lens profile, remember to configure the desired Field of view.
