Disable / enable hardware
Version2026 R2
LanguageEnglish
Added hardware is by default enabled.
You can see if hardware is enabled or disabled in this way:
Disable_enable_hardware.jpg Enabled
Disable_enable_hardware_1.jpg Disabled
To disable added hardware, for example, for licensing or performance purposes
  1. Expand the recording server, right-click the hardware you want to disable.
  2. Select Enabled to clear or select it.
