Define rules sending video to Matrix-recipients
Version2026 R2
LanguageEnglish
To send video to Matrix-recipients you must include the Matrix recipient in a rule that triggers the video transmission to the related Matrix-recipient. To do so:
  1. In the Site Navigation pane, expand Rules and Events > Rules. Right-click Rules to open the Manage Rule wizard. In the first step, select a rule type and in the second step, a condition.
  2. In Manage Rule's step 3 (Step 3: Actions) select the Set Matrix to view <devices> action.
  3. Click the Matrix link in the initial rule description.
  4. In the Select Matrix Configuration dialog box, select the relevant Matrix-recipient, and click OK.
  5. Click the devices link in the initial rule description and select from which cameras you would like to send video to the Matrix-recipient, then click OK to confirm your selection.
  6. Click Finish if the rule is complete or define if required additional actions and/or a stop action.
Note
If you delete a Matrix recipient, any rule that includes the Matrix recipient stops working.
