Daylight saving time
Version2026 R2
LanguageEnglish
When you work with a surveillance system, which is inherently time-sensitive, it is important that you know how the system handles daylight saving time (DST).
Important
Do not change the DST setting when you are in the DST period or if you have recordings from a DST period.
