Access Request Notification tab
Version2026 R2
LanguageEnglish
You can customize how your access request notifications are displayed in XProtect Smart Client when a given event is triggered.
Name
Description
Name
Enter a name for the access request notification.
Add Access Request Notification
Click to add and define access request notifications.
To delete a notification, click X on the right-hand side.
Note
If you log into the parent site using XProtect Smart Client in a Milestone Federated Architecture, you also see access request notifications from the child sites.
Access request notification details
Specify the cameras, microphones, or speakers that are displayed in the access request notifications when a given event occurs. You can also specify the sound you want to use to alert the user when the notification is displayed.
Add command
Select the commands to display as buttons in access request notification windows in XProtect Smart Client.
  • Related access request commands: enables all commands related to access request operations available on the source unit. For example Open door.
  • All related commands: enables all commands on the source unit.
  • Access control command: enables a selected access control command.
  • System command: Enables a command predefined in the XProtect system
To delete a command, click X on the right-hand side.
