Hacer una copia de seguridad de los registros del servidor
Versión2026r1
IdiomaEspañol
[en] Log data is stored in VictoriaLogs on the Management Server. The VictoriaLogs data, configuration files, and related folders are located in:
%ProgramFiles%\Milestone\VictoriaLogs
[en] Server logs and their configuration are stored separately from the XProtect configuration database. As a result, they are not included when you back up or restore the system configuration database.
[en] If you want to retain log data beyond the configured retention period or protect it against data loss, regularly back up the VictoriaLogs data and configuration files, including the .json files and data folders in the VictoriaLogs installation directory.
[en] For information about backing up and restoring VictoriaLogs, see the VictoriaLogs backup and restore documentation.
[en] Retention period
Si confía en los datos de registro para el cumplimiento o el análisis a largo plazo, asegúrese de que su estrategia de copia de seguridad tenga en cuenta el período de retención.
[en] To change the retention period, see [en] Set log retention policy. That article also includes typical retention periods for different types of logs.
