View groups
Version2026r1
LanguageEnglish
The way in which the system presents video from one or more cameras in clients is called a view. A view group is a container for one or more logical groups of such views. In clients, a view group is presented as an expandable folder from which users can select the group and the view they want to see:
Examples of view groups defined in Management Client.
Example from XProtect Smart Client: Arrow indicates a view group, which contains a logical group (called Amenities), which in turn contains 3 views.
By default, each role you define in the Management Client is also created as a view group. When you add a role in the Management Client, the role by default appears as a view group for use in clients.
  • You can assign a view group based on a role to users/groups assigned to the relevant role. You may change these view group permissions by setting this up in the role afterwards
  • A view group based on a role carries the role's name.
    Example: If you create a role with the name Building A Security Staff, it appears in XProtect Smart Client as a view group called Building A Security Staff.
    In addition to the view groups, you get when adding roles, you may create as many other view groups as you like. You can also delete view groups, including those automatically created when adding roles
  • Even if a view group is created each time, you add a role, view groups do not have to correspond to roles. You can add, rename or remove any of your view groups if required
Note
If you rename a View group, client users already connected must log out and log in again before the name change is visible.
