View Group tab (roles)
Version2026r1
LanguageEnglish
On the View Group tab, you specify which view groups the users and user groups with the selected role can use in the clients.
Specify the following permissions for view groups:
Name
Description
Read
Enables the permission to view the View Groups in the clients and in the Management Client. View groups are created in the Management Client.
Edit
Enables the permission to edit properties on View Groups in the Management Client.
Delete
Enables the permission to delete View Groups in the Management Client.
Operate
Enables the permission to use View Groups in XProtect Smart Client, that is to create and delete subgroups and views.
