Select shared backup folder
Version2026r1
LanguageEnglish
Before backing up and restoring any system configuration, you must set a backup folder for this purpose.
Right-click the notification area's Management Server service icon and select Select shared backup folder.
In the window that appears, browse to the wanted file location.
Click OK twice.
If asked if you want to delete files in the current backup folder, click Yes or No depending on your needs.
