Requirements for offline installation
If you install the system on a server that is offline, you need the following:
The
Milestone XProtect VMS Products [Release_Version] System Installer.exefileThe software license file (SLC) for your XProtect system
OS installation media including the required .NET version https://www.milestonesys.com/systemrequirements/
