Rename a user defined event
Version2026r1
LanguageEnglish
Note
If you rename a user-defined event, already connected XProtect Smart Client users must log out and log in again before the name change is visible.
  1. Expand Rules and Events > User-defined Events.
  2. In the Overview pane, select the user-defined event.
  3. In the Properties pane, overwrite the existing name.
  4. In the toolbar, click Save.
