Remove a recording server
Version2026r1
LanguageEnglish
Important
If you remove a recording server, all configuration specified in the Management Client is removed for the recording server, including all of the recording server's associated hardware (cameras, input devices, and so on).
  1. Right-click the recording server you want to remove in the Overview pane.
  2. Select Remove Recording Server.
  3. If you are sure, click Yes.
  4. The recording server and all of its associated hardware are removed.
