Presets tab (devices)
Last Updated: 3 minute read
Version2026r1
LanguageEnglish
The following devices have a Presets tab:
  • PTZ cameras that support preset positions
On the Presets tab, you can create or import preset positions, for example:
  • In rules for making a PTZ (pan-tilt-zoom) camera move to a specific preset position when an event occurs
  • In patrolling, for the automatic movement of a PTZ camera between a number of preset positions
  • For manual activation by the XProtect Smart Client users
You assign PTZ permission to roles on the Overall Security tab or the PTZ tab.
Presets tab overview for a selected device.
Tasks on the Presets tab
Name
Description
New
Add a preset position for a camera in the system:
Add a preset position (type 1)
Use presets from device
Add a preset position for a PTZ cameras on the camera itself:
Use preset positions from the camera (type 2)
Default preset
Assign one of a PTZ camera's preset positions as the camera's default preset position:
Assign a camera's preset position as default
Edit
Edit an existing preset position defined in the system:
Edit a preset position for a camera (type 1 only)
Edit the name of a preset position defined in the camera:
Rename a preset position for a camera (type 2 only)
Locked
Select this check box to lock a preset position. You can lock a preset position if you want to prevent users in XProtect Smart Client or users with limited security permissions from updating or deleting a preset. Locked presets are indicated with this icon Presets_tab_explained.png.
You lock presets as part of adding (see Add a preset position (type 1)) and editing (see Edit a preset position for a camera (type 1 only)).
Activate
Click this button to test a cameras preset position:
Test a preset position (type 1 only).
Reserve and Release
Prevent other users from taking control over the camera and release the reservation.
Administrators with security permissions to run a reserved PTZ session can run the PTZ camera in this mode. This prevents other users from taking control over the camera. With sufficient permissions, you can release other users' reserved PTZ sessions:
Reserve and release PTZ sessions.
PTZ session
Monitor if the system is currently patrolling or a user has taken control:
PTZ session properties.
View the status of PTZ cameras and manage timeouts for cameras:
Specify PTZ session timeouts.
The PTZ session table shows the current status of the PTZ camera.
Name
Description
User
Displays the user that has pressed the Reserved button and currently controls the PTZ camera.
If a patrolling session is activated by the system, it displays Patrolling.
Priority
Displays the user's PTZ priority. You can only take over PTZ sessions from users with a lower priority than you.
Timeout
Displays the remaining time of the current PTZ session.
Reserved
Indicates if the current session is a reserved PTZ session or not:
  • True: Reserved
  • False: Not reserved
The check boxes in the PTZ session section enable you to change the following timeouts for each PTZ camera.
Name
Description
Timeout for manual PTZ session
Specify the timeout period for manual PTZ sessions on this camera if you want the timeout to be different from the default period. You specify the default period in the Tools menu under Options.
Timeout for pause patrolling PTZ session
Specify the timeout period for pause patrolling PTZ sessions on this camera if you want the timeout to be different from the default period. You specify the default period in the Tools menu under Options.
Timeout for reserved PTZ session
Specify the timeout period for reserved PTZ sessions on this camera if you want the timeout to be different from the default period. You specify the default period in the Tools menu under Options.
