Notification profiles
Notification profiles enable you to set up ready-made email notifications. Notifications can automatically be triggered by a rule, for example when a particular event occurs.
When you create the notification profile, you specify the message text and decides if you want to include still images and AVI video clips in the email notifications.
Important
You may need to disable any email scanners that could prevent the application from sending email notifications.
Requirements for creating notification profiles
Before you can create notification profiles, you must specify mail server settings for email notifications.
You can secure the communication to the mail server, if you install the necessary security certificates on the mail server.
If you want the email notifications to be able to include AVI movie clips, you must first specify the compression settings:
Go to Tools > Options. This opens the Options window.
Configure the mail server on the Mail Server tab (Mail Server tab (options)) and the compression settings on the AVI Generation tab AVI Generation tab (options).
