Modify the permissions for individual alarm definitions
Version2026r1
LanguageEnglish
If you want only specific users to view and manage an alarm, you can modify the permissions for the alarm definition from XProtect Management Client. This way, you can ensure that:
  • The users receive only the alarms that are relevant to them.
  • No unauthorized users can react to alarms.
Use roles to group users that should have the same permissions for all alarm definitions.
To modify the permissions for an alarm definition:
  1. In the Site Navigation pane, expand Security, and select the role you want to modify the permissions for.
  2. Go to the Alarms tab and expand Alarm Definitions to see the list of the alarms you have defined.
  3. Select an alarm definition to modify the permissions.
