Matrix and Matrix recipients
Version2026r1
LanguageEnglish
Matrix is a feature for distributing video remotely.
A Matrix recipient is a computer with XProtect Smart Client, that is defined as a Matrix recipient in Management Client.
If you use Matrix, you can push video from any camera on your system's network to any running Matrix recipient.
To see a list of Matrix recipients added in the Management Client, expand Client in the Site Navigation pane, then select Matrix. A list of Matrix configurations is displayed in the Properties pane.
Note
In Management Client, you must add each Matrix recipient that you would like to receive Matrix-triggered video.
