Install new XProtect components
If you want to install system components on computers other than where the management server is installed, you must install these system components through the management server's download website Download Manager.
Log in to each of the other computers to install one or more of the other system components:
Recording server (For more information, see Install a recording server through Download Manager or Install a recording server silently)
Management Client (For more information, see Install XProtect Management Client through Download Manager)
Event server. Remember to restart the API Gateway after installation. If you rename the computer at a later date, you must also restart the API Gateway.
Important
If you are installing the event server in a FIPS-compliant environment, you must disable Windows FIPS 140-2 mode before installation.
Mobile server
Open an internet browser, enter the address of the management server's download web page into the address field, and download the relevant installer.
Run the installer.
See Install your system - Custom option if in doubt about the selections and settings in the different installation steps.
