Install all system components (Single computer option)
Last Updated: 8 minute read
Version2026r1
LanguageEnglish
The Single computer option installs the server and client components on the current computer.
I. The installation file
II. Language, end-user agreement and privacy settings
III. Components to install
On the Select an installation type page, select Single computerto install the all components on this computer.
IV. Password protection
V. Recording server settings
VI. Encryption
VII. Server logs
On the Server logs setup page, specify the following parameters:
  • Open Telemetry Protocol (OTLP) endpoint
  • Log language - the display language for the logs
  • Log level - select between Standard (uses less storage) or Extended (collects more data)
  • Retention period - how long the database should keep the log entries
  • Enable or disable to use Open Telemetry Protocol for server logs.
VIII. Location and language
IX. Add hardware and users
