Incident properties (Incidents node)
The following information describes settings that are related to XProtect Incident Manager.
You define all incident properties for your XProtect Smart Client operators on these tabs:
Types
Statuses
Categories
Category 1-5
All the incident properties have the following settings:
Name | Description |
Name | Incident property names do not have to be unique, but it is an advantage to use unique and descriptive incident property names in many situations. |
Description | An additional explanation of the defined incident property. For example, if you have created a category named Location, its description could be Where did the incident happen? |
