Enable recording on related devices
For camera devices, you can enable recording for related devices, for example, microphones that are connected to the same recording server. It means that the related devices record when the camera records.
Recording on related devices are enabled by default for new camera devices, but you can disable and enable as you want. For existing camera devices in the system, the check box is cleared by default.
In the Site Navigation pane, select Recording Servers.
Select the relevant camera device in the Overview pane.
On the Record tab, select or clear the Record on related devices check box.
On the Client tab, specify the devices that relate to this camera.
If you want to enable recording on related devices that are connected to another recording server, you must create a rule.
