Enable multicasting for individual cameras
Version2026r1
LanguageEnglish
Multicasting only works when you enable it for the relevant cameras:
  1. Select the recording server and select the required camera in the Overview pane.
  2. On the Client tab, select the Live multicast check box. Repeat for all relevant cameras.
Note
Multicast streams are not encrypted, even if the recording server uses encryption.
