Enable/disable privacy masking
The privacy masking feature is disabled by default.
To enable/disable the privacy masking feature for a camera:
In the Site Navigation pane, select Devices.
Select the relevant camera device in the Overview pane.
On the Privacy masking tab, select or clear Privacy masking check box.
Note
In a XProtect Interconnect setup, the central site disregards privacy masks defined in a remote site. If you want to apply the same privacy masks, you must redefine it on the central site.
