Edit settings for a selected storage or archive
Version2026r1
LanguageEnglish
  1. To edit a storage, select its recording database in the Recording and archiving configuration list. To edit an archive, select the archive database.
  2. Click the Edit Recording Storage button Edit_settings_for_a_selected.jpg located below the Recording and archiving configuration list.
  3. Either edit a recording database or edit an archive.
Note
If you change the maximum size of a database, the system auto-archives recordings that exceed the new limit. It auto-archives the recordings to the next archive or deletes them depending on archiving settings.
