Edit a preset position for a camera (type 1 only)
Version2026r1
LanguageEnglish
To edit an existing preset position defined in the system:
  1. In the Site Navigation pane, select Devices, and then select Cameras.
  2. Select the relevant camera in the Overview pane.
  3. On the Presets tab, under Preset positions, select the preset position in the list of available preset positions for the camera.
  4. Click Edit. This opens the Edit Preset window:
    Preview of the Edit preset window.
  5. The Edit Preset window displays live video from the preset position. Use the navigation buttons and/or sliders to change the preset position as required.
  6. Change the name/number and description of the preset position if needed.
  7. Select Locked if you want to lock the preset position. Only users with sufficient permissions can unlock the position afterwards.
  8. Click OK.
