Edit, copy and rename a rule
In the Overview pane, right-click the relevant rule.
Select either:
Edit Rule or Copy Rule or Rename Rule. The wizard Manage Rule opens.
If you select Copy Rule, the wizard opens displaying a copy of the selected rule. Click Finish to create a copy.
If you select Edit Rule, the wizard opens and you can enter changes. Click Finish to accept the changes.
If you select Rename Rule, you can rename the rule name text directly.
