Disable / enable hardware
Added hardware is by default enabled.
You can see if hardware is enabled or disabled in this way:
Enabled
Disabled
To disable added hardware, for example, for licensing or performance purposes
Expand the recording server, right-click the hardware you want to disable.
Select Enabled to clear or select it.
