Device pack installer - must be downloaded
The device pack (containing device drivers) included in your original installation is not included on the Download Manager. So, if you need to reinstall the device pack or make the device pack installer available, you must first add or publish the latest device pack installer to the Download Manager:
Get the latest regular device pack from the download page on the Milestone website (https://www.milestonesys.com/download/).
On the same page, you can download the legacy device pack with older drivers. To check if your cameras use drivers from the legacy device pack, go to this website (https://www.milestonesys.com/xprotect-device-packs/).
Add/publish it to the Download Manager by calling it with the --ss_registration command.
If you do not have a network connection, you can reinstall the entire recording server from the Download Manager. The installation files for the recording server is placed locally on your computer and in this way, you automatically get a reinstall of the device pack.
