Delete a storage
You cannot delete the default storage or storages that devices use as the recording storage for live recordings.
This means that you may need to move devices (see Moving hardware) and any not yet archived recordings to another storage before you delete the storage.
To see the list of devices that use this storage, click the device usage number.
Note
If the storage has data from devices that have been moved to another recording server, a warning appears. Click the link to see the list of devices.
Follow the steps in Move non-archived recordings from one storage to another.
Continue until you have moved all devices.
Select the storage that you want to delete.
Click the
button located below the Storage configuration list.Click Yes.
