Delete a camera or server tile on the System monitor dashboard
Version2026r1
LanguageEnglish
If you no longer need to monitor the hardware represented by a tile, you can delete the tile.
  1. In the System Monitor window, select Customize.
  2. In the Customize dashboard window that opens, select the tile you want to change under Server tiles or Camera tiles.
  3. Select Delete.
