Debug logs
Debug logs are used to identify defects and flaws in the system.
The following are the locations of the log files in the XProtect installation:
C:\ProgramData\Milestone\IDP\LogsNote
This is accessible only to IIS user and administrators. If the IIS user is changed, these permissions must be updated.
C:\ProgramData\Milestone\MIPSDKC:\ProgramData\Milestone\XProtect Data Collector Server\LogsC:\ProgramData\Milestone\XProtect Event Server\LogsC:\ProgramData\Milestone\XProtect Log ServerC:\ProgramData\Milestone\XProtect Management Server\LogsC:\ProgramData\Milestone\XProtect Mobile Server\LogsC:\ProgramData\Milestone\XProtect Recording Server\LogsC:\ProgramData\Milestone\XProtect Report Web Server\Logs
