Configuration Reports (System Dashboard node)
The following settings are available when creating and printing configuration reports:
Name | Description |
Reports | A list of elements that is possible to include in a configuration report. |
Select All | Adds all elements in the Reports list to the configuration report. |
Clear All | Removes all elements in the Reports list from the configuration report. |
Front Page | Customize the front page of the report. |
Formatting | Format the report. |
Exclude sensitive data | Removes personal data like user names, e-mail addresses, and other types of sensitive data from the configuration report and makes it GDPR compliant. Information about the license owner is always exclude from the report. |
Export | Select a save location for the report and create it as a PDF. |
