Change the default export settings
Version2026r1
LanguageEnglish
When you install your XProtect VMS system, the default export settings that define the export options in XProtect Smart Client are restricted to ensure the highest level of security. You can change these settings to give operators more options.
Steps:
  1. In XProtect Management Client, expand Client > Smart Client Profiles.
  2. Select Default Smart Client Profile.
  3. In the Properties pane, select the Export tab.
    The Export tab in the Properties pane.
  4. To make a restricted format available in XProtect Smart Client, find the setting and select Available.
  5. To enable operators to change a setting in XProtect Smart Client, clear the Locked check box next to the relevant setting.
  6. If relevant, change other settings.
  7. (optional) Log in to XProtect Smart Client to verify that your settings have been applied.
