Axis One-click Camera Connection (Remote Connect Services node)
Version2026r1
LanguageEnglish
These are the Axis One-Click Camera connection properties.
Name
Description
Camera password
Enter/edit. Provided with your camera at purchase. For further details, see your camera's manual or go to the Axis website.
Camera user
See details for Camera password.
Description
Enter/edit a description for the camera.
External address
Enter/edit the web address of the ST server to which the camera(s) connect.
Internal address
Enter/edit the web address of the ST server to which the recording server connects.
Name
If needed, edit the name of the item.
Owner authentication key
See Camera password.
Passwords (for Dispatch Server)
Enter password. Must be identical to the one received from your system provider.
Passwords (for ST server)
Enter password. Must be identical to the one entered when the Axis One-Click Connection Component was installed.
Register/Unregister at the Axis Dispatch Service
Indicate whether you wish to register your Axis camera with the Axis dispatch service. Can be done at time of setup or later.
Serial number
Hardware serial number as specified by the manufacturer. The serial number is often, but not always, identical to the MAC address.
Use credentials
Select the check box if you decided to use credentials during the installation of the ST server.
User name (for Dispatch Server)
Enter a user name. The user name must be identical to the one received from your system provider.
User name (for ST server)
Enter user name. Must be identical to the one entered when the Axis One-Click Connection Component was installed.
