Add a patrolling profile
Note
Before you can work with patrolling, you must specify at least two preset positions for the camera in the Presets tab, see Add a preset position (type 1).
In the Site Navigation pane, select Devices and then select Cameras.
Select the relevant PTZ camera in the Overview pane.
On the Patrolling tab, click Add. The Add Profile dialog box appears.
In the Add Profile dialog box, specify a name for the patrolling profile.
Click OK. The button is disabled if the name is not unique.
The new patrolling profile is added to the Profile list. You can now specify the preset positions and other settings for the patrolling profile.
