Access Request Notification tab
You can customize how your access request notifications are displayed in XProtect Smart Client when a given event is triggered.
Name | Description |
Name | Enter a name for the access request notification. |
Add Access Request Notification | Click to add and define access request notifications. To delete a notification, click X on the right-hand side. NoteIf you log into the parent site using XProtect Smart Client in a Milestone Federated Architecture, you also see access request notifications from the child sites. |
Access request notification details | Specify the cameras, microphones, or speakers that are displayed in the access request notifications when a given event occurs. You can also specify the sound you want to use to alert the user when the notification is displayed. |
Add command | Select the commands to display as buttons in access request notification windows in XProtect Smart Client.
To delete a command, click X on the right-hand side. |
