De logboekserver migreren
Over de migratie
[en] The log server migration copies existing log data from the log server to VictoriaLogs or your monitoring solution. It does not affect system configuration data and is optional.
[en] If you do not migrate existing logs, historical log data remains in the log server and is removed automatically according to its retention settings.
Terwijl de upgrade wordt uitgevoerd:
[en] Components that are not yet upgraded continue to send logs to the log server.
[en] Upgraded components send logs to Server Logs.
[en] Run the migration
[en] On the log server computer, go to:
C:\Program Files\Milestone\XProtect Management Server\Tools\LogServerMigrationTool
[en] Run:
VideoOS.LogServer.Migrate.exe
[en] A console window opens briefly and then closes automatically. No progress information or confirmation message is displayed.
[en] The absence of messages does not indicate an error. The migration tool runs without user interaction.
Na de migratie
De bestaande logboekgegevens van de logboekserver zijn beschikbaar in combinatie met nieuwere logboekvermeldingen in serverlogboeken.
Wanneer u de logboekserver niet langer nodig hebt, kunt u het gebruik ervan stoppen en bewaarinstellingen toestaan om resterende gegevens te verwijderen.
