[en] Set log retention policy
Versión2025r3
IdiomaEspañol
[en] Log retention determines how long logs are stored before they are automatically removed. Each log type has its own retention configuration.
[en] The configuration files are located in: C:\Program Files\Milestone\VictoriaLogs\
[en] Log type
[en] Configuration file
[en] System logs
[en] VictoriaLogsConfig_System.json
[en] Audit logs
[en] VictoriaLogsConfig_Audit.json
[en] Rule logs
[en] VictoriaLogsConfig_Rule.json
[en] Change the retention period
[en] To change the retention period:
  1. [en] Open the relevant configuration file.
  2. [en] Locate the LogRetentionPeriod setting.
  3. [en] Enter the required duration. e.g.
    "LogRetentionPeriod": "14d"
  4. [en] Save the file.
[en] Supported retention formats
[en] Unit
[en] Example
[en] Days (d)
[en] 30d
[en] Weeks (w)
[en] 4w
[en] Months (m)
[en] 3m
[en] Years (y)
[en] 1y
[en] The minimum supported value is 1d. There is no upper limit. Logs can be retained indefinitely, with available disk space acting as the only practical limit.
[en] Retention guidelines
[en] Audit logs are often retained longer to support auditing and compliance requirements.
[en] Log type
[en] Typical retention
[en] System logs
[en] Days to weeks
[en] Rule logs
[en] Weeks to months
[en] Audit logs
[en] Months to years
Aviso
[en] Audit logs can contain personal data. If GDPR compliance applies to your organization, consider limiting audit log retention to one year unless a longer retention period is required by law or policy.
