Migrando el servidor de registro
Acerca de la migración
[en] The log server migration copies existing log data from the log server to VictoriaLogs or your monitoring solution. It does not affect system configuration data and is optional.
[en] If you do not migrate existing logs, historical log data remains in the log server and is removed automatically according to its retention settings.
Migrar el servidor de registro
Mientras la actualización está en curso:
[en] Components that are not yet upgraded continue to send logs to the log server.
[en] Upgraded components send logs to Server Logs.
[en] Run the migration
[en] On the log server computer, go to:
C:\Program Files\Milestone\XProtect Management Server\Tools\LogServerMigrationTool
[en] Run:
VideoOS.LogServer.Migrate.exe
[en] A console window opens briefly and then closes automatically. No progress information or confirmation message is displayed.
[en] The absence of messages does not indicate an error. The migration tool runs without user interaction.
Después de la migración
Los datos de registro existentes del servidor de registro están disponibles junto con entradas de registro más recientes en Registros del servidor.
Cuando ya no necesite el servidor de registro, puede dejar de usarlo y permitir que los ajustes de retención eliminen cualquier dato restante.
