System Dashboard node
Under the System Dashboard node, you find different functionality to monitor your system and its various system components.
Name
Description
Current Task
Get an overview of ongoing tasks on a selected recording server.
System Monitor
Monitor the status of your servers and cameras by parameters you define.
System Monitor Thresholds
Set threshold values for monitored parameters on server and monitor tiles used in System Monitor.
Evidence Lock
Get an overview of all protected data in the system.
Configuration Reports
Print a report with your system configuration. You can decide what to include in the report.
