System Dashboard node
Under the System Dashboard node, you find different functionality to monitor your system and its various system components.
Name | Description |
Current Task | Get an overview of ongoing tasks on a selected recording server. |
System Monitor | Monitor the status of your servers and cameras by parameters you define. |
System Monitor Thresholds | Set threshold values for monitored parameters on server and monitor tiles used in System Monitor. |
Evidence Lock | Get an overview of all protected data in the system. |
Configuration Reports | Print a report with your system configuration. You can decide what to include in the report. |
