Specify the default preset as the PTZ Home position
Management Client and XProtect Smart Client users with the necessary user permissions can set up the system to use the default preset position instead of the home position of PTZ cameras with the Home button in a client.
A default preset position must be defined for the camera. If a default preset position is not defined, nothing will happen when activating the Home button in a client.
Enable setting the PTZ home position
1. Select Tools > Options.
2. On the General tab, in the Recording Server group, select Use default preset as PTZ home position.
3. Assign a preset position as the default preset position for the camera.
To assign a default preset position, see Assign a camera's preset position as default
See also System settings (Options dialog box)
